1. Dave Lazier 11.8 klde, turbo, fuel management<p>
2. Tim Lundquist 12.95 03-n20,275whp<p>3. 93mxrgs 13.30@107 ze?<p>
4. Aaronthehic 13.728@100 ze,lwr springs,tokico blues on frt, adj. fuel psi, 2.5" exhaust no cat+no headder, stage 3 cm, short throw,k8 flywheel, k+n, bf drag radials 15psi, 13" snow tires 45psi on rear, stripped, no alt., ze-cpu, 9x6 ram induction, tunable glasspack muffler,<p>
5. Jeff Abrams 13.79 klde, supercharged<p>
6. Brandon Tedder 14.231@96 ze, mx6,lwd springs, bro-speed header, cat-back, ze-ecu, fuel psi reg., msd ignition, bf drags, 9lb flywheel, stage2 cm, ?<p>
7. Smokingmx3 14.47@96 ze, lwd springs, headers, no-cat, ze-ecu,?<p>
8. cjthor 14.62@99 b6ze+mods, stripped, slicks, n2o<p>
9. Hex3 14.8@93 ze, nitto 450 drags?<p>
10. Vlad 15.008@92 97-kl03,C.A.I.,2.25" catback, tokico struts+H&R springs.<p>
11. Kurtze 15.04@? ze-bone stock <p>
12. Wkdmx3gsr 15.1 ze, catback, nitto555 drags<p>
13. Jspec 15.8 ? ze, bone stock.<p>
14. Max 15.84@87 k8, k+n-cold air intake, brullen catback, kvr drilled rotors,srd frt crossmember, srd lwr tie bar<p>
15. Mazdamxstyle 15.92@87 k8<p>
16. M.S.Steve 16.0 03-auto<p>
17. David Colman 16.05@85 k8, stock clutch, no-airbox, 195/60/15 @ 32psi.<p>
18. Custommx3 16.5@84 k8<p>
19. Nic Beique 16.6 k8<p>
20. Powerman 500 16.9@79 k8<p>I'm only doing the top 20
