grinding under the wheel well
- DJester187
just wondering on my passenger side when i cut the wheel 1/2 to all the way to the left while driving forward it makes a nasty grinding sound. now this is the only time it does this, if i cut it to the right or even going in reverse it does not make this loud and obnoxious sound. not sure if it is the axel or just rubbing (17's on lowered 1.8") any idea's?
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
Re: grinding under the wheel well
can you see any cuts in the tire or rubber on the fenders? any rubbing marks anywhere?
I had this problem for a long time and I had the bhardest time figureing it out. it was the drive axles rubbing on the plastic guards that are behind the struts. but then again I was lowered 3 inches at that point just a thought tho
|Bryan|
I got me a SPI....
I got me a SPI....
Gro Harlem
jack car up and check to see where the rims are rubbing.
my 17's rubbed the splash sheild and made a horrible sound. I never cared and now there is a big gash in the sheild from where it rubbed.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- DJester187
ok will do. i need to take off those rims and put on my stocks anyway for the winter season, so i'll get a well lit view at that time to see if rubbing or not. But if no signs of rubbing exist, it would most likely be the axel right?
sarah_percidia
I had the exact same problem, couldn't figure it out for a bit, but all it ended up being was the rotor scraping against the heat shield, just bent it back, problem solved
