I finally got around to putting my coilovers on my mx. 650 lb/in in the front, and 450 lb/in in the back. Stiff as hell, but I am setting the car up to run road courses, but still be semi-driveable. next are my custom anti-roll bars, 25mm in the front and 28mm in the rear. solid end links with poly bushings, 4 underbody braces welded in, Mazdaspeed rear suspension kit, Cusco upper camber plates, Koni red struts, front and rear triangulated strut tower braces, and a six point weld in cage. Wish me luck.
Aaron
