Torque Specs on suspension Bults?
lennis
Post by lennis »
Hi I am lowering my car with H&R springs, the upper strut bolts and the lower 2 ones I need their torque specs.. Can I get it somewhere?
I don´t have the Mx-3 repair manual..
Mx-3 GS. CAI, dtm rear muffler, H&R spring with camber bolts. Painted interior, rebuilded front with gs lip and splitters. Real supra rear wing custom fitted almost done. blue homemade underkit neon, neon inside, glasfiber glovecompartment with the headunit in. XBOX + 7 inch screen .
kr
Re: Torque Specs on suspension Bults?
Post by kr »
I think the strut to body are 60Nm and the two lower ones are 90Nm. I changed to H&R's like 6 weeks ago...
I'll check the proper torques from the manual and post them when I get home from work.
Kristian Ravantti
-- MX-3 V6 '93, still mostly stock, hasn't left the garage in ~2 years --
kr
Post by kr »
Torques (from 93 service manual)
Front suspension
strut to body: 47-62Nm
two lower bolts: 103-126Nm
piston rod nut: 79-109Nm
Rear suspension
two lower bolts: 94-126Nm
piston rod nut: 55-67Nm
Kristian Ravantti
