H&R springs, need camber kit?
lennis
Post by lennis »
Hi,
I just bought a pair of H&R springs for my mx-3 92 v6. I just wonder if I need a camber kit?
Please post sites where you can buy them in europe or companies that ships worldwide.
If you have any how to mx-3 suspension links please post them.
To do a 4 wheel align you do need a camber set, Am I right?
Thanks for reply
Mx-3 GS. CAI, dtm rear muffler, H&R spring with camber bolts. Painted interior, rebuilded front with gs lip and splitters. Real supra rear wing custom fitted almost done. blue homemade underkit neon, neon inside, glasfiber glovecompartment with the headunit in. XBOX + 7 inch screen .
TsiMiata
Re: H&R springs, need camber kit?
Post by TsiMiata »
www.whiteline.com.au
sells camber adjustment kits. It will be listed under a ford laser, mazda 323 or mazda 30x. they all use the same suspension bits.
the 30x is what the mx-3 is called down under btw.
91 Eagle Talon Tsi AWD *RIP*
TsiMiata
Post by TsiMiata »
here is the whiteline part #-
KCA412
kr
Post by kr »
The front camber can be adjusted by turning the strut mountplate. For the rear you need new bolts/alignment kit.
I ordered eibach alignment bolts from performancenter.com (but that's in the US).
Haven't put the bolts on yet, I'm getting new struts this winter and I'm not driving the car until next summer anyway...
Kristian Ravantti
-- MX-3 V6 '93, still mostly stock, hasn't left the garage in ~2 years --
