Eibach or S.T.
illicitQ
Eibach or S.T.
Post by illicitQ »
paired with the ZX2's, which is the better combo for an rs?
92 RS: BPT, evo front mount, custom 2.5 in IC pipes, apex-i SAFC- II, GReddy type-RS BOV, rear disc swap, GTX front strutbar, oem GS lower rear tie bar, Topspeed1 axle back exhaust, 15" TSW wrapped in yokohamas, power window swap. NOT INSTALLED: GReddy turbo timer and CS downpipe.
mazdubber
Re: Eibach or S.T.
Post by mazdubber »
I say Eibach. But ST's are very good quality as well.
92 GS
'Stock'... :twisted:
drift
Re: Eibach or S.T.
Post by drift »
eibach. the zx2's were ment to be paired with them.
quicksliver
Re: Eibach or S.T.
Post by quicksliver »
If you own an RS, Suspension Techniques. If you own a GS, then Eibach with no doubt in my mind.
Suspension Technique lowering spring were NOT designed for the weight of the V6, says right on the packageing that it's for the 4cyl. I got Suspension Technique lowering springs on my V6, and they clunk over every god damn bump.
