H&R Springs with ZX2 Struts
Alright guys, I installed this combo today but for some reason the front pass. side sits about half an inch higher then the driver side. I enlarged the hole on the upper spring perch to fit the new thrust bearing so I thought I'd ask before go taking that shhit apart. Thanks
Re: H&R Springs with ZX2 Struts
did u cut your bumpstops? they probably require some trimming
