Rear Discs?
Posted: September 23rd, 2003, 5:45 pm
by Rylinkus
I'm not big on the whole MX3 trim levels, but did any of them come with rear discs? If not, does anyone know if the rear spindles from a PGT/6LS would be compatible with the 3 so as to perform a rear disc conversion?
Re: Rear Discs?
Posted: September 23rd, 2003, 8:25 pm
by Rylinkus
Ummmm........
My friend's GS with 1.8L V6 certainly seems to have drums on the rear by my semi trained eye....
Re: Rear Discs?
Posted: September 24th, 2003, 5:07 pm
by Zebaj
'93 GS definately had drums. Unless I got a wacky deal. peace.
Re: Rear Discs?
Posted: September 24th, 2003, 5:13 pm
by Custommx3
My GS had all disk brakes, 93. Seems as every US spec GS had rear disk brakes,
Re: Rear Discs?
Posted: September 24th, 2003, 9:44 pm
by JasonH
Ditto. My '92 GS(USA) had rear discs, and my '93 GS(CAN) has them too. If there's a GS that came stock with rear drums, it has to be an anomaly.
Re: Rear Discs?
Posted: October 13th, 2003, 3:36 pm
by odds1
my GS have disk brakes too. It's the european spec.
Re: Rear Discs?
Posted: November 10th, 2003, 1:44 am
by ruthless_mx3
my 93 gs se has rear disc too
just had to get another post
Re: Rear Discs?
Posted: November 10th, 2003, 3:21 am
by Gro Harlem
My 93' has discs too, and I can't figure out how to get the flipping things off!! I removed the screws but part of the hub is in the way of them. WTH!
anyone got quick pointers?
Re: Rear Discs?
Posted: November 10th, 2003, 4:06 am
by millionflame
There's two bolts that hold the calipers on. If you remove those, then the whole thing will come off.
I had no problems removing mine, nor did anything obstruct me from taking them off either.
~A
Re: Rear Discs?
Posted: November 10th, 2003, 1:12 pm
by Gro Harlem
I removed my caliper too..but there are like...two pointy things in the way where the caliper bracket is that get completely in the way of removing the rotor.
The main obstruction is the fact that the rotor can't "angle" out of the way of those bracket things b/c of the lugnut studs. At least thats how my car is...its non-abs
Re: Rear Discs?
Posted: November 10th, 2003, 5:28 pm
by millionflame
Is your rotor screwed into the hub still?
Re: Rear Discs?
Posted: November 13th, 2003, 12:26 am
by Casino
use like an impact wrench to remove some of the screws cause they can be a pain.
