Rear Discs?
Rear Discs?
I'm not big on the whole MX3 trim levels, but did any of them come with rear discs? If not, does anyone know if the rear spindles from a PGT/6LS would be compatible with the 3 so as to perform a rear disc conversion?
1993 Undercover MX6 LS ('93 Probe GT)
Stage 1 Weight Reduction (Door Panels fell off)
Aerodynamic Body Mod (Antenna broke)
Custom Lowering (Broke Rear Springs)
Advanced Navigation System (New girlfriend to check maps)
Re: Rear Discs?
Ummmm........
My friend's GS with 1.8L V6 certainly seems to have drums on the rear by my semi trained eye....
Re: Rear Discs?
'93 GS definately had drums. Unless I got a wacky deal. peace.
- Custommx3
- Site Administrator
Re: Rear Discs?
My GS had all disk brakes, 93. Seems as every US spec GS had rear disk brakes,
Re: Rear Discs?
Ditto. My '92 GS(USA) had rear discs, and my '93 GS(CAN) has them too. If there's a GS that came stock with rear drums, it has to be an anomaly.
- ruthless_mx3
Re: Rear Discs?
my 93 gs se has rear disc too
just had to get another post![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Image](http://i140.photobucket.com/albums/r16/mzdaspdmx3/IMG_0229.jpg)
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
Re: Rear Discs?
My 93' has discs too, and I can't figure out how to get the flipping things off!! I removed the screws but part of the hub is in the way of them. WTH!
anyone got quick pointers?
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- millionflame
Re: Rear Discs?
There's two bolts that hold the calipers on. If you remove those, then the whole thing will come off.
I had no problems removing mine, nor did anything obstruct me from taking them off either.
~A
~A
~ Millionflame (94 GS 120K)
Re: Rear Discs?
I removed my caliper too..but there are like...two pointy things in the way where the caliper bracket is that get completely in the way of removing the rotor.
The main obstruction is the fact that the rotor can't "angle" out of the way of those bracket things b/c of the lugnut studs. At least thats how my car is...its non-abs
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- millionflame
- Casino
Re: Rear Discs?
use like an impact wrench to remove some of the screws cause they can be a pain.
