http://www.jgstools.com/turbo/thk.html
Check the mazda on the middle of the site.
Is that thing work?
I have made around 175 hp easily with 7 psi on a stock 1.6L 16v sohc engine, using 1/4 mile times and vehicle weight.BuGS wrote:If you can weld that would work. I would still say hold off and find a BP engine then swap that over. From the power you will get out of the SOHC from turboing it you can get out of a N/A BP. Then turbo the BP and have around 200HP relativly easy. Thats what I am doing anyways...
How much have you spent? I have so far spent around $1000 and have a BP (with rebuilt head), G series Tranny, Harness, ECU, Turbo (with less then 1mm of shaft play), Manifold, IC, and Greddy Emanage with PC tool. Now a couple more hundred for oil lines IC pipes and dyno tuneing then prolly around $500 for exhaust, then $200 more for injectors and new fuel pump, so around $1900 and I will have around 225 HP to the wheels.Stevo wrote:I have made around 175 hp easily with 7 psi on a stock 1.6L 16v sohc engine, using 1/4 mile times and vehicle weight.BuGS wrote:If you can weld that would work. I would still say hold off and find a BP engine then swap that over. From the power you will get out of the SOHC from turboing it you can get out of a N/A BP. Then turbo the BP and have around 200HP relativly easy. Thats what I am doing anyways...
Stevo
That is the price if you purchase it with it already welded together. If you do the whole thing yourself then the kit is only $150.00What wrote:wow, $250USD just seems like a bad deal for a log-style manifold that you still have to weld up a flange for and cut holes in. I'd just go with something custom (and done) from a reputable builder that makes good stuff.
