				Turbo Timer Install questions?
				Posted: May 27th, 2004, 12:31 am
				by mx34u2nve
				Im installing a greddy turbo timer. I have a couple wiring questions that would be easily solved by the online shop manual that got removed. But anyways I need to know what the four wires are coming off the ignition are (colour coded) 1 should be accessory, 1 should be start, 1 should be power, and the other should be somethin else.... And then I need to know which wire is the speed(ometer) wire going into the ECU. tHanks
				Re: Turbo Timer Install questions?
				Posted: May 27th, 2004, 2:56 am
				by IanL
Accessories AND Run is Black/White
 Run is Black/Red
 Run AND Start is Blue
 Start is Black/Blue
 Speedo to ECU is Black/White, goes to ECU terminal 1M.
				Posted: May 27th, 2004, 9:26 am
				by mx34u2nve
				Thanks a lot for the quick response. So which of those 4 wires is going to be the 12v constant power. and how do i know which terminal on the ecu is 1M. Thanks
				Posted: May 27th, 2004, 3:35 pm
				by IanL
None of them; the wire with constant power is the Black, its the supply from the 100A main fuse.
I'll email you a diagram
				Posted: May 27th, 2004, 3:38 pm
				by mx34u2nve
				PLEASE REPLY TO
PUNK_WISE@HOTMAIL.COM THANKS A LOT
				Posted: May 27th, 2004, 3:46 pm
				by IanL
				Done!
				Posted: June 4th, 2004, 4:02 pm
				by Roadracer_X
				IanL,
    Do you happen to have a diagram telling which wire is which in the diagnostic port under the hood? I have a 93 1.6 and I'm going to tap into the diagnostic port to use a lap top to manipulate the ecu. Any help will be greatly appreciated.
            Thanks
