Turbo Timer Install questions?
Im installing a greddy turbo timer. I have a couple wiring questions that would be easily solved by the online shop manual that got removed. But anyways I need to know what the four wires are coming off the ignition are (colour coded) 1 should be accessory, 1 should be start, 1 should be power, and the other should be somethin else.... And then I need to know which wire is the speed(ometer) wire going into the ECU. tHanks
							Turbo 2.5l mx3
						Re: Turbo Timer Install questions?
Accessories AND Run is Black/WhiteOriginally posted by mx34u2nve:
Run is Black/Red
Run AND Start is Blue
Start is Black/Blue
Speedo to ECU is Black/White, goes to ECU terminal 1M.
Re-shaped and re-sized gearshift lever.  Best driveability mod you can do!
Thanks a lot for the quick response. So which of those 4 wires is going to be the 12v constant power. and how do i know which terminal on the ecu is 1M. Thanks
							Turbo 2.5l mx3
None of them; the wire with constant power is the Black, its the supply from the 100A main fuse.Originally posted by mx34u2nve:
I'll email you a diagramand how do i know which terminal on the ecu is 1M.
PLEASE REPLY TO PUNK_WISE@HOTMAIL.COM THANKS A LOT
							Turbo 2.5l mx3
Done!
				Roadracer_X
IanL,
Do you happen to have a diagram telling which wire is which in the diagnostic port under the hood? I have a 93 1.6 and I'm going to tap into the diagnostic port to use a lap top to manipulate the ecu. Any help will be greatly appreciated.
Thanks
Thanks
Why go only a quarter of a mile when you can take the road course and go all the way!
