Today I wanted to replace my wipercontrols, so I pulled the aftermarket steering wheel off, all the covers and than I wanted to pull the steering hub off. But with alot of force (and I do mean alot), it wouldn't even move a bit. What am I doing wrong, please help.
Bastian
How to pull off my momo steering hub??
Black Magic
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
marshmallow15
Re: How to pull off my momo steering hub??
did you try removing the center 21mm nut first?
- team slideways
- team slideways
Black Magic
Yes ofcourse I took that off first, but than the hub is still stuck like #@$%. So what to do?
Bastian
Bastian
remove the 21mm nut.... then bolt the wheel back on to the hub and give it a pull.
Black Magic
Oke, thanks, I'll try that. I hope that it'll work out, it must be very stuck because I couldn't pull it out the first time. I'm a pretty strong man, but didn't manage to get it out by trying to pull out the hub alone. But this weekend I'm gona try it again.
Thanks, Bastian
Thanks, Bastian
marshmallow15
yea cwhat wolfman said should work ok. jsut be careful not to strip the bolts that hold the wheel in. also try prying it off with a breaker bar. or let it soak in wd40 first.
- team slideways
- team slideways
