Reman T3 from JGS turbo....look!
- cjthor
Allright. After ripping apart my T3 I find out that it is destroyed. The compressor housing and center section is waay over clearanced. I found http://www.jgstools.com/turbo/ and they can use my exhaust housing and get me everything else reman with a .06 trim and a .42ar. Also this new compressor housing will be water cooled. All for about 275. Howz this sound??
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- cjthor
Re: Reman T3 from JGS turbo....look!
Just called again and he said to make it a t3/04B would be about 400..Whats the diff between t04E and a T04B?
Jarid Perry
About 30 year old technology. The T04B was used during the late 70's and 80's, its a decent turbo for good gains but the T04E will spool faster, operate more efficiently and is of a newer design.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by maldo:
About 30 year old technology. The T04B was used during the late 70's and 80's, its a decent turbo for good gains but the T04E will spool faster, operate more efficiently and is of a newer design.<hr></blockquote><p>Yes, but since he has a t3 turbine housing, it will spool at the speed of a t3 (aprox. but very close). $400 is a VERY good price for a water cooled t3/t4 design turbo. Jarid, check a few more things. See how much for a BB turbo which will give you faster spool and longer life, and also see if you can get a to4e compressor. Just for comparison sake. (I may have you hook me up 'once again' and send you my turbo to have them build)
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by VizualXTC:
<p>Yes, but since he has a t3 turbine housing, it will spool at the speed of a t3 (aprox. but very close). <hr></blockquote><p>Do you have any data proving that, or are you just making it up?
David Coleman
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by David Coleman:
<p>Do you have any data proving that, or are you just making it up?<hr></blockquote><p>No, I have no data but I have LOTS and LOTS of hearsay. I have people that know a LOT more than I do about turbos, engines, tuning, and cars in general that have tole me that on many occasions.<p>[ January 17, 2003: Message edited by: VizualXTC ]</p>
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
- cjthor
Allright. I am sending my exhaust housing off to the guys at jgstools.com and they are going to install a new center section and compressor housing. Should have it back in about a week. Watercooled here we come!
Jarid Perry
- cjthor
Just to keep you guys posted. Lance at JGStools.com was easy to work with. My turbo is already on its way back to me. It's a 60 trim and a .48 a/r turbine. Should be here monday and I will shoot some pics
Jarid Perry
- cjthor
Well it showed up today. I am happy with the overall experience with these guys. It was pretty inexpensive for what I got accomplished....a reman t3 w/exhaust flange for a tad over 200. Here's a pic with my manifold and turbonetics wastegate.<p>
Jarid Perry
I REALLY hope that manifold is 321 Stainless Steel or your gonna have a lot of problems with cracking! Who did the manifold? What materials were used? They are hopely good at calculating & reproducing the correct exhaust sign wave right? If they didn't engineer it on a correctly calculated sign wave then the turbo will have pretty poor response throught the entire power band! Not to mention MUCH lower power output numbers, possibly even shock wave damage on the thrust bearings, turbine shaft, & seals. Wish you the best of luck though!
i thought the manifold looked like a very nice design. as far as i know jgs tool uses weld els which are very strong. anyways congrats on the setup--very nice..
- cjthor
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by JWMotorsports:
I REALLY hope that manifold is 321 Stainless Steel or your gonna have a lot of problems with cracking! Who did the manifold? What materials were used? They are hopely good at calculating & reproducing the correct exhaust sign wave right? If they didn't engineer it on a correctly calculated sign wave then the turbo will have pretty poor response throught the entire power band! Not to mention MUCH lower power output numbers, possibly even shock wave damage on the thrust bearings, turbine shaft, & seals. Wish you the best of luck though!<hr></blockquote>
\ Wow sounds dangerous? I got the manifold from Jademx3. I am contemplating getting a different style but for now this will do..
Jarid Perry
that looks fine. i wouldnt bother changing it. ive seen log style manifolds produce over 400hp. looking at the runners it looks like the pulses should be correctly spaced. On a street turbo system it is hard to meet every aspect of a "perfect" turbo manifold. alot of factors are involved, strength and durability being the most important. this manifold looks to serve its purpose.
I REALLY hope that manifold is 321 Stainless Steel or your gonna have a lot of problems with cracking! Who did the manifold? What materials were used? They are hopely good at calculating & reproducing the correct exhaust sign wave right? If they didn't engineer it on a correctly calculated sign wave then the turbo will have pretty poor response throught the entire power band! Not to mention MUCH lower power output numbers, possibly even shock wave damage on the thrust bearings, turbine shaft, & seals. Wish you the best of luck though!<hr></blockquote><p>
I take it you are in the manifold business? <p>For what I have found, you can practically make a manifold out of toilet paper tubes and bondo and have it work as well as some of the beautiful stainless, equal-length header systems I have seen.
Stainless has NO mechanical advantage over mild steel except corrosion resistance. Period.
As far as equal pulse length, there is nothing sinusoidal about exhaust pulses, so I don't know what you are talking about when you say "correct exhaust sign[sic] wave".
There is much to gain in POWER by having the pulses line-up, but the turbine will not "feel" any damaging pulses unless some of them are going the wrong direction, like backwards.
My system uses the stock logs and two fairly uneven collectors and I have no lag (sometimes I wish I did) and as much power as I like. Keeping the fuel and ignition timing up with the flow of air is the only real problem that I had to solve.
