wet or dry system on the B6T?
Shady469
Post by Shady469 »
I've decided, for the time being, in order to be a competitor in the turbo-4 class i'm gonna have to spray (untill i get a turbo upgrade). I was looking at the NX system but got to thinking:if i'm running alot of boost do i want fuel diverted? or is the amount of fuel for say a 70 shot not enough to effect delivery from the injectors. so i started thinking about the dry NOS set-up. I'd like to go with the NX, but not if it'll hurt my boosting.or should i just hold off untill i can afford a direct port system?
thanx in advance for any replies.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
boostedmx
Re: wet or dry system on the B6T?
Post by boostedmx »
the direct port system is nice, i would save for that. hits alot harder too. i have the zex kit om my 240sx and its not as nice.
JWMotorsports
Post by JWMotorsports »
Deffinately good with a WET nitrous kit! It is your safest bet for now and later. Direct port fogger systems are the most effective. However you could go for a single fogger somewhere after the turbo, before the throttle body. NOS makes a NOSzle WET nitrous kit that would work (75-150HP adjustable). It uses a adapter that sits under your fuel injectors so you don't have to do any drilling. However it is almost $1000.
Return to “Forced Induction”
