Is there a compatable turbo engine in the 1.8v6 GS?
PJT84
Post by PJT84 »
I'd like to know if theres any engine swap that is possible, i've only heard of a klze swap in the 1.8v6 dohc. If there is a turbo available what hp increases and performance increases are expected.
maldo
Re: Is there a compatable turbo engine in the 1.8v6 GS?
Post by maldo »
DO A SEARCH!!!<P>Try B6T or BPT.
VizualXTC
Post by VizualXTC »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by maldo:<BR><STRONG>DO A SEARCH!!!<P>Try B6T or BPT.</STRONG><HR></BLOCKQUOTE><P>B6T and BPT in the V6? Wouldn't that be a little too labor intensive? Why not just say "Hey, the KLZE and KL03 are pretty much drop in applications. You can turbocharge both engines, but you may encounter preignition above 8psi of boost, depending on the grade of fuel available in your area, on the ZE (giving aprox. 290HP) or 10psi on the 03 (giving aprox. 260HP) depending on the application. There are no turbo kits available for either engine from what I know."<BR>Wasn't that a little nicer? :D<p>[ April 19, 2002: Message edited by: VizualXTC ]
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
The_Great_Tonge
Post by The_Great_Tonge »
Visual you get a :D while other smart asses on this board get a big old :mad:
PJT84
Post by PJT84 »
hey i appreciate the info---and i did do a search. I'm just debating about keeping the mx-3 or possibly going to get an mr-2.
maldo
Post by maldo »
If I have to be a smart as to convince others to do a search before asking questions that have been dealt with time and time again then so be it. I suppose you guys aren't the ones getting 20-30 emails a week about the B6T swap.<P>Glad you did a search though. There is a turbo kit for the 1.8l that fits the 2.5l but is essentially crap, it is made by TKT. Kitchen pots as heat shields should explain everything.
David Coleman
Post by David Coleman »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by VizualXTC:<BR><STRONG><P>B6T and BPT in the V6? Wouldn't that be a little too labor intensive? Why not just say "Hey, the KLZE and KL03 are pretty much drop in applications. You can turbocharge both engines, but you will have to do internal work if you want more than 7 PSI on the ZE (giving aprox. 290HP) or 10 PSI on the 03 (giving aprox. 260HP) depending on the application. There are no turbo kits available for either engine from what I know."<BR>Wasn't that a little nicer? :D</STRONG><HR></BLOCKQUOTE><P>It may be nicer, but it was not entirely accurate, and did nothing to answer the original question. <P><A HREF="http://members.attcanada.ca/~dragon64/dave.html" TARGET=_blank>Dave Lauzier</A> thought ditching the V6 for the BPT was a good idea...
David Coleman
PJT84
Post by PJT84 »
From what i see i guess the bpt is the set up to go, but won't that be rather difficult or expensive to change from a 1.8v6 to a 1.8v4? i just wanna make sure i have things right or figured out.
maldo
Post by maldo »
Now we're getting somewhere. The only real problem that I can see is getting your hands on all of the 4 cylinder bracing. You would need the RS motor mounts and I believe you have to modify one of them but I could be wrong. Give Derrick (corksport) a call regarding compatibility of mating a v6 tranny to the BPT. I know the Pro LX uses the G series and will bolt up but I don't know if the v6 tranny shares the same bell housing. Basically, check the online shop manual for the different bracings between the 2 models, I would assume that that should do it. Of course you will need the basic FI parts, a pro lx ecu or GTR (have fun finding one), wiring harness from either a Pro or RS. <P>Any questions regarding upgrades for the BPT, do a search on this site or come join the Yahoo 323GTX egroup for more info.
Return to “Forced Induction”
