Check out the pics of my shaved door handles and my engine bay with the battery moved to the trunk. Let me know what you think. Only had it for two or three months now. It'll be a mustang and honda killer soon
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
Stock 1995 RS - Creek Blue
Car Meanins:
1. couldn't put in the civic intake unless i moved the battery
2. probably doing turbo later on
3. wanted more space in the engine bay to work on the engine
4. improve weight ratio
i picked up a relocatin kit from summit racing... but the box that came with it is just temporary... I am having a mettal one custom built for a 5"x9"x9" yellow top optima battery in a week or so. The only pics i have of that so far are the ones in the engine bay cause the trunk mount isn't anything special
