Not sure how many guys have fibreglassed their interior, but I'm wondering what would be the best material to use to create round corners. I've heard just cloth, and then fibreglass over top of that.
If cloth is the best, do you just add resin to it, form it, let it try and then continue fibreglassing over top of that?
I'd like the custom area to have lots of shape, round corners and so forth and have the patience to do this myself, even with no experience, but these corners are started to scare me.
Thanks for your time
Fibreglassing custom hatch interior
Chicks dig orange cars
![Image](http://slowbellie.com/jobomx3.jpg)
i know this is an old a-- topic but i am thinking of doing the same thing and i was wondering if you did it and how it turned out ?
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
Use carpeting, the stuff they use for sub boxes.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
what about making the entire thing out of fiberglass or covering the one i have now in it ? and do you think somehtig like bondo-glass would work because i have some from my friends CRX that i can try
CTC Racing
92 1.6L
92 1.6L
- PATDIESEL
I use fleece not carpet. It has almost no pile and that makes the resin covering almost ready for paint. All you do is form a substructure out of some wood, then staple the fleece over the wood sturcture and apply resin to the top of the fleece. Take the dried fleece out of the car and lay fiberglass on the under side to add stregnth. Then bondo the top side so that you can sand to a smooth finish and paint. Easy really, jsut time consuming.
Also, try something small a few times to get used to making the wood understructure and what the wood needs to look like to get the desired look from the fleece when you lay the fleece over the top.
I need to acknowledge Kevin, owner of Barney and Elmo (2 highly modded MX-3 show cars) for teaching me how to create a fleece fiberglass piece.
