My new LED driving light!!! but having problem in instal
where do u get power for fog/driving light usually?
<small>[ January 01, 2004, 04:18 AM: Message edited by: greatunicon ]</small>
a
- ryanlindenberg
Re: My new LED driving light!!! but having problem in instal
you will want to run a relay setup. you will probably want to hook the driving lamps up to an independent switch or else have them only turn on when your high beams do. if you don't you will be blinding people and will get pulled over.
CARDOMAIN WITH UPDATED PICS
Moved to Lighting. Please continue your discussion there.
