Page 1 of 2
5 mechanics later, still got a strange sound from Front
Posted: November 11th, 2004, 1:33 pm
by quicksliver
I have taken my car to 5 different shops now and not one has been able to give me any clear idea what's wrong with my poor mx ;(. Here goes...
Whenever i turn right my driver side wheel seems to almost feel like the tire or something is actually bumping across the road.
Here is the catch though...
It's wayyy more sensative to bumping with even the slightest turn of the wheel to the right after the car has been sitting for a while.
After it's been on the road for about 20 minutes, it's not anywhere near as sensative to bumping when i turn the wheel to the right a bit....i will now have to REALLY turn the wheel to the right hard to feel the bumping in the front driver side wheel area.
I have had 3 different wheel combinations on (205/55/15 and 205/40/17 and 205/60/15), and i STILL have this crazy bumping sound whenever i turn right.
Here is my setup...
1992 Mazda Mx-3 GS
ZX2 Struts
ST Lowering Springs
I would REALLY appreciate any feedback on this. Cause the mechanics around here are usless.
<small>[ November 11, 2004, 12:37 PM: Message edited by: Quick Sliver ]</small>
Re: 5 mechanics later, still got a strange sound from Front
Posted: November 11th, 2004, 1:42 pm
by papa roached
maybe the axels are shot?
Posted: November 11th, 2004, 2:19 pm
by mitmaks
worn struts or bad axle
Posted: November 11th, 2004, 3:00 pm
by quicksliver
That's the thing. The axle is new!!
Posted: November 11th, 2004, 3:26 pm
by lakersfan1
Did the noise start with the replacement? Or is the noise exactly the same and just as frequent before and after the replacement. And I'm assuming you actually did the replacement yourself or saw the new axle? If a mechanic did it, I wouldn't doubt he tried to just reboot the axle and charge you for a new one.
Posted: November 11th, 2004, 3:37 pm
by quicksliver
The noise started right after the mechanic changed the axle. I initialy bought the axle at Canadian Tire (cause its a lifetime warranty), and then brought it into the shop and had the mechanic put it on.
I brought the car back into the mechanic a few days after he put it on, explained the problem, and he looked over it but said everything was fine and that it's probably my strut that needs replaceing (This was back in Feb 2004).
To date i still don't have this fixed. However, im starting to think i have a faulty axle...is this even possible? Should the 'Lifetime Warranty' cover the cost of replaceing the part?
Posted: November 11th, 2004, 3:52 pm
by lakersfan1
Sure it's possible. If it's remanufacturered like the lifetime warranty ones at Autozone, they could have missed something out of spec with the old core and just threw a new boot on it and called it a day when it may have needed some machining done. Just swap in a new one. The warranty will probably only cover the part itself. If I were you, I'd just do it myself anyways. Not that hard if you have access to a socket set and a long (24") breaker bar.
Posted: November 11th, 2004, 7:13 pm
by DavidOS
brakes? wheel bearings, ball joints,
Posted: November 11th, 2004, 8:00 pm
by RoundTop
I almost never notice the slight bumping sound. only in one turn..and that one is a bad turn of bad road and I am 90% sure it is the road.
other than that nothing. But I do know that my CV boots need replacing soon, so it is probably just that. And it almost never happens.
Posted: November 11th, 2004, 9:00 pm
by rdawg000
if ur axles are new manybe its ur CV boot ! the clip thats inside the boot might not be on correctly ! that could cause the bumping! just my 02
Posted: November 11th, 2004, 10:17 pm
by Trevor
I've Got sort of the same problem and I just diagnosed it as a Bad Ball joint. any mechanic should figuer that one out pretty easy. jack up the driver side control arm to get the Tire in the air and keep a load on the ball joint. grab the top and botom of the tire and try to wiggle it to cheack for play in the ball joint. if there is none then give the wheel a spin if u hear a crunching noise u need to replace your wheel bearing. good luck
Posted: November 11th, 2004, 10:18 pm
by Trevor
another thing it might also be is the strut bearing if it's worn or not seated right
Posted: November 12th, 2004, 10:29 am
by yemc
[QUOTE]Originally posted by Quick Sliver:
I have had the same problem and it took many trips to the shop to get it sorted.
your main wishbone bush is screwed! get them swapped out. not to expensive. get your cv's greased up while they have it apart!
Posted: November 12th, 2004, 11:59 am
by Gro Harlem
our cars don't have wishbones.
This is just a wild guess, but maybe your thrust bearing (strut bearing) is farked on one side? that would cause a weird vibration and strange steering feel fo sho.
Posted: November 12th, 2004, 12:15 pm
by quicksliver
OH i should also mention that i get the same bumping sound/feel when i go over DIPS in the road...not bumps, but DIPS. Because of this, im leaning towards ball joint maybe?
