Speedchip
IceRod
Speedchip
Post by IceRod »
Hi,
When strolling on ebay i found the following:
"+20HP SPEEDCHIP MAZDA MX3 MX6 PRECIDIA".
"This simple modification will allow you to boost the power output of your vehicle's engine, without sacrificing reliability or comfort. It consists of a small RESISTOR CHIP that will be inserted between your car's IAT sensor. You will feel the gain instantly, no expensive tuning necessary. This unit will work with all cars equipped with electronic fuel injection. Most of the cars manufactured after 1990 are equipped with E.F.I."
It only cost 4 bucks so i thought this must be some scam. Or is it? I have a 94 mx-3.
fry_81
Re: Speedchip
Post by fry_81 »
ya its a scam. i think it just pumps more fuel into the engine.
papa roached
Re: Speedchip
Post by papa roached »
sux, scam, do not buy or you will be castrated with a rusty spoon :p
IceRod
Re: Speedchip
Post by IceRod »
Hahaha, I sure don't want that to happen =P.
But thank you for the quick replies.
Just got to stay away from everything thats cheap ;)
