KLZE Swap & Turbo
KLZE Swap & Turbo
I am considering swapping my 1.8L for the 2.5L KLZE-30. Wanted to see if anyone has any advice on this, as to i have no clue on any of it. Also, Do you know where i can get this engine from at a good price? Lastly, whats the opinion on dropping a turbo into this baby?
Re: KLZE Swap & Turbo
There is Lots of advice on the KLZE engine on this site it's one of the most talked about things do a search you'll come up with a ton of info
Yeah man just search it, there is a ton of info. If you don't know anything about it don't even think about turboing right now.. I got my motor at nippon-motors.com and it's in excellent condition.. There are a number of other places... try googling it
GS-R SE
Fixin's
also you may wanna try searching on probe talk 2 they have alot to do with the KLZE.
If you research it properly> it tells you what you need, how to do the swap, and how to set the klze up>>>
This site is one of the best sources I have come across for a car
check my car domain
http://www.cardomain.com/ride/2144443
soposively you can run up to 7psi on the klze, but most recomend 5psi.
I wanna see someone do the miller cycle motor one day someone will!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- babyblueMX3
I've seen 9.5 psi on stock internals on a zeOriginally posted by Mnemonic:
RIP 400whp ZE-T MX-3
I got mine form sunsengines. Not a bad price, and the engine showed up REALLY clean. Haven't installed it yet, but all looks well.
There's a ton of info on this site, bro. One word:
search. Print out the good ones, and you'll have enough reading material for a hundred trips to the bathroom.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
