ok i've read several different posts and still no unchallenged answer. the curved neck ze w/ kl01 cams, does anyone truly know how many hp this engine is? some say 190hp, others say 174hp, then even fewer say 196 hp. can someone please answer this once and for all w/ a little proof (dyno'ed would be awesome)thanks in advance. (i'm too poor right now to dyno )
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
174's should be for American spec KL31 engines (Millenia). AS for Jap spec KL31 head motors, I believe the KL01 cams are supposed to put out 197 HP, but since the manual tranny ECU's we get are for the straight neck KL31 engines, the VRIS points are a little off and result in more like 190HP.
even if the code on the head is kl01 not kl31 (it is jspec tho, and yes i have the kl 36 ecu)
I guessed the car with me in it weighs 2700lbs, I'm 150lbs.
Assume a 30hp drivetrain loss and I have 198hp at the engine. I'd say my mods might have added 10hp. So stock it would have been 188hp. This was all in 90+ degree humid as hell florida heat. If it was cooler and less humid out I might be good for another 10 or so HP.
I'd say the stock power has got to be in the 190's.
i got the ZE with the curved neck manifold and it has kl-101 and kl-1A1 on the heads, and trust me u can tell its a ZE, i was worried at first but i read here that it is the lower compression ZE with around 190hp instead of the higher compression 200hp one, but she still has lots of balls.
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
ok well i have the kl01 cams but the head code is the kl 101 and kl 1a1 but i was told it was a ze?! i mean i paid ze price! it looks just like this )
yup, thats the exact same kind i got with the kl-101 and kl-1A1 heads, its the ZE, that one looks pretty clean too.
mine was a little dirtier than that, but not by much. so which is it the 174 or the 190ish? anyone?!
An engine as clean as that would be quite young, and therefore more likely to be the lower compression version (9.2:1) of the JDM engine, with 187hp SAE (190PS). That's not too bad, and it should pass emissions much more easily, as it's been detuned to meet the new higher JDM emissions standard.
ok sounds good, cuz that means that later if i so choose i can put more boost than the higher (10:1) compression engine right?
Hey I got the same curved neck ZE like the picture above but mine has kl31 1a1 and kl31 101 heads with kl-01 camshafts. I thought this was the ZE version not the regular millenia engine with kl 101 and 1a1 heads
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
