Hey all, just got my KL-ZE installed this week and having a problem with the gas pedal. It's basically stuck and i can't move it. When I go to start my car the RPMs run way up. Seems like the gas pedal is stuck. I'm not to sure what's going on. I've tried a search but didn't get any results. If anyone can throw Ideas my way that would be great.
<small>[ June 06, 2004, 12:48 PM: Message edited by: your2slow ]</small>
Gas Pedal Question
Gas Pedal Question
KL-ZE, Custom Intake, Apex Lowering Springs, and more to come this year.
Toronto Mx-3 Club
My Cardomain Site
Toronto Mx-3 Club
My Cardomain Site
Re: Gas Pedal Question
If I were you I would check your throttle cable and your TB and make sure that it isnt adjusted wide open. Hope this helps.
Ya i'm thinking it's the throttel cable. Any other Ideas out there that would cause this? Thanks for the responces.
Toronto Mx-3 Club
My Cardomain Site
Toronto Mx-3 Club
My Cardomain Site
- PATDIESEL
When I did my swap I had trouble getting the mounting hardware from the cable to find a good spot on the ZE to bolt them down. Check those too, the cable was binding and caused mine to stick. Alittle moving them around and everything was fine.
