i would love to throw down sub-12's at the track
How much power from K8?
				NateDog
how much power can be made from the K8?  i get razzed at the part store about having a 1.8L V6 so i want to know how much power can i make out of the engine?  is 300+whp possable from the engine?
<img src="http://www.inuyasya.com/A-HASIRU-S.gif" alt=" - " />
						- papa roached
Re: How much power from K8?
not gonna happen man, i think you might able to get like 200-250 HP from it with some serious turbo love
				curtklze
300 W.H.P. is no problem.
actually you COULD get about 450-500 at the engine before you have to worry about the stock crank.
Yes, I AM a bastard
						Yes, I AM a bastard
- papa roached
i did not know that.....
				TsiMiata
Anything is possible it just takes $$. Put some rods, pistons, turbo and all the other things that go with it in there 25psi of boost and you might make it. Figure it would cost you $10-$15k.
91 Eagle Talon Tsi AWD *RIP*
- mitmaks
200whp is gonna be very fast, 500hp, youll pee your pants if youd drive car with 500hp, youll be lucky if you come out of it alive lol, want 500hp get muscle car
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
