klze swap problem
korban
klze swap problem
Post by korban »
when i start the car, it redlines .
any idea what might be wrong.
Still have stock 1.8l ecu ..
is there anyone here that has a clue?
can anyone msg me a number perhaps and i can explain better over the phone.
Thanks.
IanL
Re: klze swap problem
Post by IanL »
This may be a little obvious, but have you checked your throttle is not stuck open?
korban
Post by korban »
checked the throttle already.. think its electical or a vacum line ... dont know what it is. its baffleing me and getting really frustrating..
DavidOS
Post by DavidOS »
yah thats vaccum related make sure all vaccum lines are hooked up and that the little breather ontop of the motor is closed off or plugged up.
Gabi
Post by Gabi »
Give me a call, if still have problems. 851-7786
See you in my rear wiew!!
DaKLzE
Post by DaKLzE »
Hey guys..Im new to this..and Im really frustrated...Im going bald from this. OKay, I see you guys have done the KLZE swap. I just got my KLZE in today.. and I finished wiring everything, but for some apparent reason, i still have 4 harness clips that are hanging loose. I try to start the car, adn all i get is the starter relay clicking, but no turn. Please Help Me..Please??!?!?!?!?
korban
Post by korban »
my swap is finalize and running beasty :) yes. the clips are a bugger to fix up unless you have labeled them before hand.. Take some picks ill try and help you out. the solonoids where the trickiest for me.
