MTX Fluid?
MTX Fluid?
I replaced my drive axles and lost a bit of fluid and I was wondering what fluid I need to replace it with and how do I put it in the trany?
Re: MTX Fluid?
75W90
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- Zoso124
Re: MTX Fluid?
Of the different ones I've tried I've been happiest with the Royal Purple brand.
Mike Evans
Gone:
Gone:
Re: MTX Fluid?
Redline MT90 is the only way to go. This stuff works amazingly well. Shifter goes into gear so easily after I replaced my fluid with this stuff.
Expensive, but why buy crap $2/qt fluid when it comes to your transmission? Redline is like 8 a qt but you only have to change the fluid every 30k miles or so...so its worth the extra $$$
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: MTX Fluid?
Ditto.Originally posted by Zoso124:
Re: MTX Fluid?
I changed to pensoil synchromesh (autozone, $5/q, compatible with coper in tranny). It really helps to smooth the shifting.
Re: MTX Fluid?
What is best for automatic transmissions? Re schaeffers any good? I heard yes.
