which thermo spacer to use?
For KLZE: with MS8 manifold, do you still want the kit Outlaw sells for the KLZE or do you want the KLDE 2.5 spacer?  With the K8 manifold do you want the one made for the KLZE or for the K8? I don't want to buy the wrong one =)
							1992 MX-3 GS
KLZE - Fidanza Flywheel - CM IIR Clutch - Millenia IM - UR Pulley - IM Spacers - KL36 ECU
Re: which thermo spacer to use?
Originally posted by thebox:
For KLZE:
- babyblueMX3
yeah both uses the ze
							RIP 400whp ZE-T MX-3
