Well,
I have a Ze and i used my K8 mainfold, and i have a big leak in the upper right side.. But im using an 97 millinia gasket..So i guess my question is, are they compaible and i just have them on wrong, or do i need to buy a new gasket. ...thanx in advance..
well i dunno for sure but i would assume you want a gasket for a K8 since you are using the K8 manifold, i can't think of any good reason that wouldnt work. i would assume the gasket made for a specific manifold would work better on that manifold rather than a gasket that is made for a different manifold. but of course i speak only logic here, and no i have not researched this at all =)
no you don'T want to use the k8 gaskets...the ports on the ze heads are big square and the k8 gaskets are small and round..don't use the k8 gaskets..use millenia gaskets...same heads as the ze..it'll work fine with millenia's
