signal lights... Does anyone have the same problem
babygirl23
Post by babygirl23 »
I WAS WONDERING IF ANYONE COULD HELP ME OUT I HAVE A 95 MX-3 AND EVERYTIME I MAKE MAKE A RIGHT TURN AND PUT MY SIGNAL ON MY FRONT HEADLIGHTS GO OUT AND I HAVE NO CLUE WHY? I WAS THINKING IT WAS A WIRING PROBLEM.
Bri94GS
Re: signal lights... Does anyone have the same problem
Post by Bri94GS »
I would guess you either have a short in a wire, or maybe one of your fuses is blown.<P>------------------<BR>~'94 GS
~Bri - Morph860@aol.com
'94 MX-3 GS (FOR SALE!)
'04 Mazda 3s 5-door
zoom-zoom
mxcess
Post by mxcess »
Maybe you should make all left hand turns! Image Just kidding! It might be a short in the turn signal switch since the headlight controls are also located on the same switch. It is a job probably better left to the profesionals since you will have to remove the steering wheel to get to the switch. Good luck, Robert.
Guest
Post by Guest »
The headlight switch has three wires comming from it, a green , red, and black. ANd the Turn signal is operated my A ball bearing style operation in the column itself. What I m tryin to say is that the problem is more likely happening in the bumper cover area. Someone may have wired lights in or something and got the wires back words. Im not quite sure what to say but check the wires harness that come from the headlite bulbs them selves and trace the wires back as far as you can to see if you see any tampered with wiring. Chris <BR>Same with the turn signal wires.
