Bad shifting, need input
Guest
Post by Guest »
Ok I have been reading for the last half an hour in the archives. My car seems to have a common problem. It shifts like ****, Especially second gear. From all the things i read there wasnt much addressing the actual problem, just beating around the bush. So my question is who here has had this problem, and had it partially or completely fixed? <p>Im taking my car in on tuesday (3 days) to get an axle shaft replaced so I want to have them look at that too. And I want to have some knowledge about the problem.<p>So anyways any help would be great, also are shifter bushings generic? or are they specific to each car? and how much do they run?<p>Thanks alot!
Timothy Dawson
ghandi1981
Re: Bad shifting, need input
Post by ghandi1981 »
yea im getting almost the same problem....it is hard as hell to get into 1st gear....and while i am driving sometimes its hard to shift into the next gear....any suggestiongs????<p>aj
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Guest
Post by Guest »
Well i just got a new clutch so there is new transaxle fluid and its full, this problem existed before the new clutch, and im almost positive my transmition is fine because once in a blue moon my car shifts like a dream, especially the first day i got it back with the new clutch, but soon after it was back to same old.
Guest
Post by Guest »
bump
zytariuk
Post by zytariuk »
It's hard to get mine into 1st if im driving. So instead I just go from 2nd...to neutral...come to a complete stop...then shift into 1st (very smooth).
pelado
Post by pelado »
Try replacing the front and rear motor (actually transmission) mounts.
Oliver
Post by Oliver »
Well, if some of the gears shift harder than others, and you somtimes get smooth shifts i'd say your syncro's are wore. Try matching your rmp's on your shifts, and double clutch, if you get it right it should shift smooth even if your synco's are wore out. Although this might be a little tricky because the rpm's drop on these engines pretty quick. Just throwin some ideas out.
ghandi1981
oh yea forgot to mention....when the car is off i can shift into gears fine....????but when i turn it on..unless it is already in first gear....its hard as hell to get it into first gear....<p>
aj
codyhoover
Post by codyhoover »
All GS do that im pretty sure. Mine only has 60,000miles on it and i know there is nothing worn out and mine does it too. It just wont let you shift into 1st above like 15 miles an hour. something to do with the sycros.
-Cody
Green '92 GS
140db on 1 12"
ghandi1981
it wont let me shift into 1st when im at a stop light....unless i push real hard....<p>aj
Coodoodxx
Post by Coodoodxx »
Mine isn't having problems shifting into second, it just won't got back into first somtimes after ive been waiting at a light in neutral. I have no clue why.
'93 mx-3, 1.8L V6, Red
red-mx3
Post by red-mx3 »
It isn't unusual for a manual transmission to not go into first gear easily when you come to a stop. When it happens just clutch then go into some other gear (second, third, whatever), then go into first and you'll find it usually goes in smooth and easily. Just a suggestion .....
ghandi1981
have less than 700 miles on new clutchmaster III clutch....what happens when there is air in the system????<p>aj
