Sunroof Sticky
Sunroof Sticky
My sunroof has just started sticking and won't open unless I give it a little puch from inside. I've lubricated the tracks and hinges, but it doesn't seem to help. Once the sunroof has made the initial "pop" out of its closed position, it works fine-- same as it always has. Any ideas on what the problem could be?<P>Thanks!<BR>Chas.
Re: Sunroof Sticky
It's just your sunroof engine getting weak. Mine is doing that from time to time and also won't go back while shutting it down unless I help it. I mean it goes all the way back but doesn't go down, stay up. It's most definitely a weak sunroof engine.<P>------------------<BR>Frenchguy0<BR>'92 GS Emerald Green<BR>crenia@hotmail.com
Re: Sunroof Sticky
I have the same problem here.. My sunroof is stinky sometimes..I don't know why.. <P>Hey guys..Do you have some crackling sound from your sunroof when you take a tinny hole in the street?? Cuz it sux
