Kewl pix, no one would ever suspect that its a 200hp J-Spec engine, especially since you have the stock intake manifold. BTW why did you keep the k8 intake manifold?
Umm, I dont believe that is the K8 manifold...but...if you can prove me otherwise...<BR>I'll check for the numbers...kl 31 is it? Im going to search for that anyway...<p>[ September 23, 2002: Message edited by: killerpickle ]
Tom Alexander
full custom black and red interior / KLZE ECU / JE50 VAF http://home.cogeco.ca/~mx3/ - updated dec 1/03
the people that did your swap must have put on your 1.8 intake because that is not a kl-ze intake from want i know <BR>it might be a kf-ze intake or engine
where did you get it done?<P>if it was at a-spec they put your stock intake on to make it fit<BR>you are losing horse because of it <BR>a-spec does cut and weld the mx-6 kl-ze intake to make it fit into a mx-3 but it is not as good as a ms8 manifold<BR>and the last time I was there they had one
200 hp is with all things being equal, which they are not, as in you need a better exhaust, jspec im, jspec ecu(no cel dammit!), and 94+ octane in our gas type, and that looks like a k8 manifold, dah well
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
the mx-6 kl-ze intake manifold does not fit a mx-3<BR>you can get it cut and welded to fit <BR>the ms-8 manifold does fit it is another version of kl-ze
holy responses...<BR>ok.<BR>I know for sure that it is not my original k8 manifold. Mine was corroded like crazy and very stained. Maybe I should stop being lazy and look for a part number. Isn't it maybe the mx6 manifold? My idle is dead on perfect. And there is no way its the kf-ze, it feels twice as fast (yes I know its not but...).<p>[ September 24, 2002: Message edited by: killerpickle ]
Tom Alexander
