Cheap Intake for V6 or I4
This will work on both 4 and 6 cylinder engines...go out and buy a ractive intake for a 92-95 civic. u will need to cut about 6 inchs off the long end depending wether or not its a 4 or 6.......i just guessed and it worked out good.....u need to remove the overflow for the rad located in the bottom right side of the engine compartment. after u move a few cables and wires it gives u a clear hole to put the filter down into...""""""""""remmeber to file down and then clean the egde u cut"""""""""""""""""" u don;t want any file shavings going into your intake!!!!!!!!!!!!!! using the same clamps and parts from the ractive intake u can bolt it right in....then replace the rad over flow and with a few wiggles it will all work together no subports are needs for the tube but i do recomend that u put some tape or a piece of foam on the metal part where the tube rests.................for pics goto my page <A HREF="http://importa.tripod.com/mike.html" TARGET=_blank>http://importa.tripod.com/mike.html</A> later....................also if u own a v6 i had problems with my intake in the cold and wet winters............in the cold weather the engine would start to run ruff and then the engine light would come on.......once i stopped and started it again for awhile it ran ok......after putting my stock air box back in the car ran like new!!!
