amp question
Car Stereo/Alarm Discussions
novadoc
amp question
Post by novadoc »
just wondering if i can wire two dual 4ohm VC subs to a single amp and run it at 2 ohms<p>and what amp would you recommend
NoVa<p>Image
2fazed
Re: amp question
Post by 2fazed »
Yes, as long as the amp is 2ohm stable. Well to decide about what amp to get. Look at your subs wattage ratings. Try to match your rms watts at 2ohms. For example: If your subs are 500rms to 1000max, then your amp should be at least 500rms at 2ohms.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
novadoc
Re: amp question
Post by novadoc »
Earthquake PH500.1 2-Channel Amplifier
Key Features:
Two channels of operation
1500 Max Power Output
1 x 750 W at 4 ohms bridged
2 x 375 at 2 ohms stereo
2 x 250W at 4 ohms Stereo
Built-in variable crossover- VARIXR
Low-pass, full range, or high pass operation
Two independent low level RCA inputs
Two independent high pass level inputs
Two crosssed audio signal RCA outputs
Remote gain control + Localized gain control
Signal to noise >104 dB
THD of less than 0.016% at any output
Damping Factor over 200
Current Draw idling: 1.2A
Current Draw with music: 24A
Fuse Raiting: 30A
Dimensions: 2.5 x 10.5 x 13.5<p>running 2 of these<p>alpine sub<p>[ February 06, 2003: Message edited by: NoVa ]<p>[ February 06, 2003: Message edited by: NoVa ]</p>
NoVa<p>Image
Return to “Car Stereo/Alarm”
