Amp rack
Posted: December 31st, 2002, 1:28 am
by o0mx30o
hey guys im new to this board but im building an amprack built into my trunk and i need some sort of miror like for the inside of it i was wondeirng does chrome paint work? or do i have to use actual mirrors, if i use mirrors will i be able to drill a hole wihough shatering them? and another question my amp rack is basically i took out the spare tire and built a new floor over the trunk and then bolted a box to the bottom and im having a plexiglass window, will i need a computer fan to keep the air cool or will my amp not overheat, i have a JBL 180.2 amp (360rms) do i have to worry about it overheating.. i will post pics of what i have so far
Re: Amp rack
Posted: December 31st, 2002, 5:51 pm
by monty73741
you can get vynal that look like mirrors
jason
Re: Amp rack
Posted: December 31st, 2002, 5:56 pm
by o0mx30o
what store sells this? in canada (BC), i dont have a credit card so i cant order from the net
Re: Amp rack
Posted: December 31st, 2002, 10:15 pm
by Talon_66
Loopy1 - Where abouts in BC are u?
Re: Amp rack
Posted: January 1st, 2003, 5:33 pm
by o0mx30o
I live in south surrey/whiterock
Re: Amp rack
Posted: January 1st, 2003, 9:36 pm
by JWMotorsports
You could also use mirrored plexiglass. That way you can drill or what ever you want. Or if you need something stronger go with mirrored Lexan. Check your local auto glass shops.
Re: Amp rack
Posted: January 1st, 2003, 10:11 pm
by o0mx30o
i will look into that when i get the glass for my rack but i think im going to dimond plate it. What about the problem with air flow no one answerd yet, will i need a fan or just a few holes will do?
Re: Amp rack
Posted: January 2nd, 2003, 2:41 am
by monty73741
yeah should be fine for air flow.....
just have an inlet hole & outlet hole
jason
