Amp rack
Amp rack
hey guys im new to this board but im building an amprack built into my trunk and i need some sort of miror like for the inside of it i was wondeirng does chrome paint work? or do i have to use actual mirrors, if i use mirrors will i be able to drill a hole wihough shatering them? and another question my amp rack is basically i took out the spare tire and built a new floor over the trunk and then bolted a box to the bottom and im having a plexiglass window, will i need a computer fan to keep the air cool or will my amp not overheat, i have a JBL 180.2 amp (360rms) do i have to worry about it overheating.. i will post pics of what i have so far
- monty73741
Re: Amp rack
you can get vynal that look like mirrors
jason
jason
Jason Danaher
Please Help Support MX-3.com
Re: Amp rack
what store sells this? in canada (BC), i dont have a credit card so i cant order from the net
Re: Amp rack
Loopy1 - Where abouts in BC are u?
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Amp rack
I live in south surrey/whiterock
Re: Amp rack
You could also use mirrored plexiglass. That way you can drill or what ever you want. Or if you need something stronger go with mirrored Lexan. Check your local auto glass shops.
Re: Amp rack
i will look into that when i get the glass for my rack but i think im going to dimond plate it. What about the problem with air flow no one answerd yet, will i need a fan or just a few holes will do?
- monty73741
Re: Amp rack
yeah should be fine for air flow.....
just have an inlet hole & outlet hole
jason
jason
Jason Danaher
