Alerm System
Car Stereo/Alarm Discussions
greatunicon
Alerm System
Post by greatunicon »
Do u guy know, how to install a Keyless entry system to a 93 Mx-3 GS????, and it already have a CIFFORD Alerm,<P>is that difficlt to do ?? or how much to cost to install it from store.?? :)
a
Sonicxtacy02
Re: Alerm System
Post by Sonicxtacy02 »
well if you have two options, either buy a stand alone system and have two sets of remotes, or impliment them into your existing system. If you choose the second route i would advise you to take it to the shop as the wiring and programming could get tricky. Install from the shop it shouldnt cost more than 80 labor
Shaun Newman
Sonicxtacy02
Re: Alerm System
if the alarm already has the connections than installing the actuators is easy. If you already have power locks, you only need one actuator. You can be them from <A HREF="http://www.partsexpress.com" TARGET=_blank>www.partsexpress.com</A> for cheap, and they arent that difficult to install. Now as far as the relay's, they are a little tricky to understand, but if i can do it there's no reason you cant :).<P>Keyless is probably the most helpful addition i put in my car, no more frozen lock problems!
Shaun Newman
Return to “Car Stereo/Alarm”
