You havent been around very long and you seem to know quite a bit about MX-3's...
Are you a Mazda Super Hero?
Whos the man behind the mask?
& whats up with the name??
Inquiring minds want to know. (well, really just me... LOL)
The bodys on both the RS and GS are exactly the same. If you go to a junkyard that you can pick your own grab one (dont forget the bolts) and it will bolt right in. Also consider the rear lower tie bar, should bolt right in as well. Gives you a bit better handling.Originally posted by David Witherow:
hey how did you get the GS from transverse x-member to work on your GS
DAVID! HOPE I CATCH YOU IN TIME ON THIS. The SRD front x-member/transverse member WILL NOT work on the RS.Originally posted by David Witherow:
see thats what i thought cause srd makes one and i was told that they dont work on the RS but if you bolted it on then i may order one....
Hey thanks Gro but I don't have that swap on my radar... quite yet...Originally posted by Gro Harlem:
So when are you doing the BPT swap into that RS of yours? You can do it in my a/c'ed 2-car garage. I've already done a BP swap & i'm working on swapping the 1.6 out of my 323 for a 1.8 right now..should be done tuesday.
