what messanging program do u use
- monty73741
I have all of em....yahoo, icq, aol, msn
but i mainly use aol
Jason Danaher
Please Help Support MX-3.com
- mitmaks
Re: what messanging program do u use
i got aol, and yahoo. use yahoo mostly
I use the one and original ICQ, been using it since about '96-'97, i have msn only cause its the one all the cool kids are using now
- cjthor
I have em all but use AOL mostly..two screen names
Rogue Mx3 and Cjthor5
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
just to let everyone know go download trillian (go to google and type free trillian) and you can use yahoo aol msn icq and irc all at the same time. thats what i use then you can delete all the other programs and save space on your comp. its very nice and easy.
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
man iraq sucks!!!
95 MX-3 RS
man iraq sucks!!!
- papa roached
my experience with trillian is it blows, they are seperate for a reason, i use Yahoo, MSN, AIM
Trillian is good stuff and if you have a job where the IT dept. blocks AIM, ICQ, MSN & yahoo, you can often set up trillian w/settings thru a free proxy server (addresses available on the Net, ck. w/a google search) and it will get thru the network firewall... and all other IM buddy lists are available to ya.
Hey papa roached, not sure what probs you've had with trillian, other than they hafta keep updating the free software to stay ahead of the others which try to devise blocks so you might temporarily find trillian blocked out of AIM for example. The designers put it togehter because all the other services refuse to consider interoperability between their programs.
- papa roached
i have had file tranfer issues and stuff like that, decided it was easier to just have them seperate and its no big deal to keep it that way on my main system but i can see what you say about using it at work
- monty73741
is owned by aol...
that is why u can use icq # on aim
is owned by aol...
Jason Danaher
- Custommx3
- Site Administrator
AIM only.. have ICQ, but I dont use it
