which engine do i have?
Off-Topic Discussions
Wildman640
Post by Wildman640 »
I just bought a 92 gs and the guy said the motor had been changed out recently. Im not sure if it is still the 1.8 or a bigger one. The only thing it says on top is Mazda 24 valve DOHC. Is there anywhere else I could check to see what size it is?
mitmaks
Re: which engine do i have?
Post by mitmaks »
yes u have 1.8 V6 unless he changed it to klze which i doubt
Wildman640
thanks
Wildman640
so my prm from the 4cyl should work then
mitmaks
Post by mitmaks »
yes it should, i adapted civic intake just relocated coolant overflow reservoir and it fit right in, of course u have to run it after VAF or it wont run right.
VizualXTC
Post by VizualXTC »
you need to look on the heads. If it says K8 101 then it's a 1.8L. I don't know what the KL heads say, but I'm sure it says KL XXX. Just look between the intake runners and you'll see them on the rear head.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Wildman640
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by VizualXTC:
you need to look on the heads. If it says K8 101 then it's a 1.8L. I don't know what the KL heads say, but I'm sure it says KL XXX. Just look between the intake runners and you'll see them on the rear head.<hr></blockquote><p>i just checked and it is the K8 engine. Thanks for the info tip
Return to “Off-Topic”
