I usually run my air all the time.
I mean the temps down here rarely go below 85.
Now, the temps outside are cooler now about 78 and I am not using the air as much.
The idle is now much better. If I put it into neutral, it is even better, staying around 750 RPMs.
Does anyone have any ideas as to what I can do to help the idle with the air on?
I think the problem may be related to the AC.
Any suggestions would help.
Thanks
![Welder :welder:](./images/smilies/welder.gif)
