flood damage
dr. gonzo
flood damage
what would a car that was damaged in a flood and is not running but will turnover need? the motor seems fine, im thinkin ecu is damaged. what else would need replaced?
some peoples kids.
- mitmaks
Re: flood damage
check for water in oil, id recommend new filters, oil, tune-up.
Re: flood damage
I'd check compression or leak down. Never know if it 'hyrdaulicd' trying to compress water sucked through the intake.
