UR flywheel
mxprecidia
UR flywheel
i just got my unorthodox racing light weight flywheel..it looks pretty sweet...can anyone tell me what to expect? did anyone else install this?
www.illegalCustoms.com
Tri-State Area Car Club
mxprecidia
- mitmaks
Re: UR flywheel
well you just bought it and dont even know how it improves the car???? well i guess some people got more $$ than me...
well anyways your engine will rev up faster and you should get a few hp/tq increase since its lighter than stock one.
mxprecidia
Re: UR flywheel
i know what it does i was trying to make conversation looking for opinions of what other buyers thought of it jectoid!
but anyway...has anyone else bought the UR flywheel? is it a nice performance upgrade? how much of a HP increase did you get? thanks
- papa roached
Re: UR flywheel
i got a 9lb Fidanza on my KL-ZE, you will notice huge gains in first, some in second, hardly in 3rd, with each gear the gains drop BUT it should really liven it up for ya, i love mine
and attacking a long standing membor of this forum isnt a nice thing to do
<small>[ October 19, 2004, 02:52 PM: Message edited by: papa roached ]</small>
Re: UR flywheel
I actually installed the UR Flywheel just about a month or two ago. It is said to add 15-25whp. Pretty sure you already know but wheel horsepower is better than base horsepower. I can feel the difference driving the car with the flywheel. It goes up hills easier, do not have to downshift as often when rpm's drop, and acceleration has gotten better. It is true that it is better in lower gears than higher but still decent in higher gears. I say it is a good mod . you can check out my car at cardomain.
bolt on cars are pointless you learn nothing and it's just too easy. http://members.cardomain.com/lujacks
