I NEED A HEADER
I NEED A HEADER
the name says it all really i need a header, anyone know where i can get one ?, i need it kinda fast
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
Re: I NEED A HEADER
Ebay. Look up probe headers
Purple Honda Eater rollin' on 17in Fuzions with custom intake and cracked windshield
- papa roached
Re: I NEED A HEADER
might be nice to tell him how to make it work so he dont get one and come back beating on you because it wont bolt up
Re: I NEED A HEADER
i have a 1992 SOHC 1.6 so will the probe header still fit ?and if not do they make one ?
CTC Racing
92 1.6L
92 1.6L
Re: I NEED A HEADER
Ok 1.6sohc then check this one
Eugene L
1.6DOHC
N.S.canada
http://www.cardomain.com/memberpage/552384
Eugene L
1.6DOHC
N.S.canada
