Exhaust Install Question
mclaw-mclaren
This maybe a dumb question. But is it typical or normal for a shop to remove your o2 sensor when you get new exhaust. I mean like whole piping and stuff?
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
pelado
Re: Exhaust Install Question
If they're replacing from the exhaust manifolds back, then yes - they have to remove them.
mclaw-mclaren
k, i got my cat removed because i needed a new one, and just put another resinator in. then the piping starts where the cat was. is that from the exhaust manifold??
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
white fish
the o2 sensors are in the down pipe but before the cat most people just get a "cat back" and there is no need to remove the O2's
mclaw-mclaren
