washer lights 92GS
JonBMX3
washer lights 92GS
Post by JonBMX3 »
I bought washer lights for my 92GS, and I would really like to install them. The only problem is... I can't figure out how to get my old washer lights off! Any advice on how to remove the stock washer lights would be great! Anyone who has done this mod, or knows how to remove the original washers, your advice is greatly appreciated! my e-mail is jbentz@mix.wvu.edu, or you can just reply here on the BB, and I'll catch it! Thanks
92RedMX3
Re: washer lights 92GS
Post by 92RedMX3 »
I plan on getting some but I never plan on hooking up the lights. Usually washers are expensive. You might have to drill to get those in though. All I know is my washers are horrible.
rece
Post by rece »
u have to use needle nose pliers to squeez the old ones out, plan on a couple bloody knuckles and to get the new ones on u might need to bend the enclosure in a little to get the washer on the new ones it took me about an hour to do this <P>ps u need to take off the heat guard and be VERY careful not to break the push tabs, i used sone thick string and wraped it all the way around and pulled hard and quick<P>oh yeah dont drop then into the engine because u sure as hell aint gona see it again<P>hope this helps
Jesse<BR>red 92 gs
