coilovers
304N
coilovers
Post by 304N »
i wanted to know if i installed coilovers, would i also need to change my strus also????please help...thanks in advance..
http://members.cardomain.com/str8304 <p>"JUST TRYIN' TO BLEED THE BLOCK"
fictionaldaydream
Re: coilovers
Post by fictionaldaydream »
I had a question something like that so maybe it will help if I just post here.<p>I needed to know if the tokico struts will be okay with dropzone coilovers, I hope someone help.
ryanlindenberg
Re: coilovers
Post by ryanlindenberg »
you don't HAVE to change the struts. your car will handle better if you do. and you will probably ruin your stock ones after awhile because they are not made to be used with lowering springs or coilovers.
CARDOMAIN WITH UPDATED PICS
