windshiled problems
windshiled problems
I don´t know what these things are called, but you know the ones that spurt water on the windshield, I want to remove them and replace them with new ones, I´ve tried that but with no success, that seems impossible or at least it seems it would take a h*ll of a job.<P>Anyone got a tip? how should i do?
dam2009
Re: windshiled problems
windshield washar fluid nozells. they snap on and lock,that's why it's so hard to remove them. I'm not saying is't impossible to get them out, but since you're getting new ones just break them.
yea... but how will i put the new ones there? is it difficult? i want to keep my old ones...
dam2009
they snaps-on. just push it down and that's it. however some of them are tread-on,where you have to put a nut from the other side and tight it down.
- airjordon_09
ok, doing this is one of the EASIEST things to do, if your still interested in doing it, email me and i will give you the easiest step-bystep there is, airjordon_09@hotmail.com<P> peace
just get a pair of "long needle nose pliers" remove the hose then you should see the tabs sqeeze them and pull it out
http://members.cardomain.com/anjin1982
Maintaining my MX-3 in it's natural beauty state...Although i love the modded one's!!!
dam2009
and as soon as you sqeeze them they break.<P>airjordon . what are the steps?
dam2009
that's what I thought.
if you sqeeze too hard then yea but on mine i had those lighted 1's i swapped them out for the oold 1's again the hardest part was putting on the lighted 1's they had nuts (threaded) oain in the a$$ since theirs no room for much pliers
