Need swaping Info.
Need swaping Info.
I want to swap over a 1993 Mx-3 (4 cly, 16v, 1.6L)To a v6 1.8L or 2.5 what parts do I need to change and what is the proceedure. If you can give me some advice, maybe a website, or any related documents I would be grateful. If this job is imposible then how to change the auto. transmission to manuel on the 4cly. Thanks
- cjthor
Re: Need swaping Info.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by NFStewy:<BR><STRONG>I want to swap over a 1993 Mx-3 (4 cly, 16v, 1.6L)To a v6 1.8L or 2.5 what parts do I need to change and what is the proceedure. If you can give me some advice, maybe a website, or any related documents I would be grateful. If this job is imposible then how to change the auto. transmission to manuel on the 4cly. Thanks
</STRONG><HR></BLOCKQUOTE><BR> The V6 is next to impossible to swap in. If you do a search in the 4cyl forum under " transmission swap" or "automatic to Manual" you should find something.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Check the I4 FAQ. Its not impossible or anything like that but it takes MANY parts. It is usually cheaper to get one with a V6 to start with.
jeff
Yeah I think that you would be better off just getting the GS cause swapping the 2.5 into the 4cyl it a VERY expensive way to go, and time consuming
Thanks for the advice people, I will look into it! I have spoken to many others, some say the transmission and 1.6L from 323 are enterchangebul and others say the only thing for me are 1992 or 1993 Mx-3 parts. Could someone clear up this issue. I Need A manuel transmission what can I use. oh yea and 5spd_GS what do you think I am doing, is this not searching.
